Magic chef gas oven problem
Our oven burns high yellow flame and lots of soot . Replaced the ignighter and would like to know how to adjust oven burner flame
Cuddy,
Sounds like you’re using LP Gas and have not converted the range from Nat gas.
What about the top burners, same problem ?
Or did they forget to convert the oven ?
All you can adjust is the air mixture at the burner, by loosenning the screw on the shutter and opening/closing until you have a nice blue flame, but thats not going to solve the problem, at this point.
Good Luck,
