Hi.
Last night my wife was trying to bake cookies for christmas, and the oven kept shutting off. She had to stand right next to the oven for about 2 hours just to keep turning it back on. the cook top works fine. PLEASE HELP.
Thanks Tom
Hi.
Thanks Tom
Can you describe it more specifically?
It was set at 350 worked fine for about an hour then it would shut off and loose temp until we turned it back on. It did that for the rest of the night.
it would heat up to the set temp 350 shut off and loose temp until we turned it back on. it repeated this for a couple hours
When you said: “shut off”, did you mean just the heating element or the display as well?
Yes both would shut off. I would hear the display “click” off then the oven would loose temp until we turned the display back on.
