I have replaced the heating element. Now I cannot get belt to tighten back around drum. The assembly arm with a roller has a spring. but there are three holes the spring could go into. I have tried all three. The arm is set suggly under the motor. Everything feels tight. I get the drum on, belt on. I spring the drum and the belt comes back off
I looked for a diagram that would show how to re-assemble, but I do not find one. Your customer service desk said to come here for answer. Dryer is apart right now. Or should I call?
it doesn’t matter now, I broke the little spinley rod coming from the motor that is suppose to help hold the assembly arm for the tensioner. I am not going to take the motor apart to change it…
