I can’t read a thing off the label. It’s just a solid silver metal label.
It’s a Magic Chef electric wall double oven.
It is 24 inches wide and 48 inches tall approx on the height.
http://s344.photobucket.com/albums/p334/scri8er/Picture010-1.jpg
http://i344.photobucket.com/albums/p334/scri8er/Picture009.jpg
It’s installed in the wall of course. Is there some where else I can retrieve the model number on this oven?
I need to find replacement parts for this double oven. This is for a rental property.I am not at the rental property. So I don’t have access to the oven.
The upper oven is not working. The lights are not turning on … on the control panel/dashboard.
No heat in the upper oven comes on. Only the lower oven came on before we took it apart.
We do not have electricity at this property right now.
Upper heating element damaged spot on coil need to replace
http://i344.photobucket.com/albums/p334/scri8er/Picture013-1.jpg
http://i344.photobucket.com/albums/p334/scri8er/Picture016.jpg
This is a thermostat?
120-240 Vac BONK! Can’t find this part
(has the chunk blown out of it)
http://i344.photobucket.com/albums/p334/scri8er/Picture011.jpg
Don’t know if I need this?
This is a controller? Made by RobertShaw
EA69F-24-48
7404P039-60
OT-012-012-99
30A277 VAC
DL 500 F CL 940F
http://s344.photobucket.com/albums/p334/scri8er/Picture012.jpg
Here is the results for one of the parts. I guessed as best I could not having the model number.
http://************************************/Catalog_Detail.aspx?inventory=1653787
I don’t know if this is needed or if it is the correct part for this oven that I don’t have a model number for.
I’m all ears. Thank you for your time and help.
