I have a magic chef dishwasher (model #DU2J) that came with our Double Wide. It started leaking so I replace the seal around the door, which wasn’t the solution. It’s leaking from the bottom of the door about 3 inches from the right corner. What should I do to fix it?
[QUOTE=Beckyt55;11378]I have a magic chef dishwasher (model #DU2J) that came with our Double Wide. It started leaking so I replace the seal around the door, which wasn’t the solution. It’s leaking from the bottom of the door about 3 inches from the right corner. What should I do to fix it?[/QUOTE]
mine is leaking in the very same place and it has stopped cleaaning well. Does anyone have a manual (in english) fir this model?
Thanks for any help!
Frank
