Magic Chef Dishwasher not draining
Dishwasher will not drain. It appears that the timer is not engaging the solenoid that allows the cycle to drain.
Timer dial turns through cycle to the stop position. Machine seems to stay in the “wash” cycle throughout the time it runs.
Should I try timer or the solenoid.
Thanks -
Pump assembly replacement parts for MAGIC CHEF DU75CA-01 Dishwasher - Undercounter | AppliancePartsPros.com
I would get a meter and measure across the solenoid when it should be powered. If you see 120 volts then either the solenoid is toast or you have a mechanical problem with the solenoid or the flapper valve.
If no power then it is either the timer or a wire from the timer to the solenoid is broken/open.
You can then check the voltage and continuity of parts.
I did the troubleshooting below, still no drain.
Then I disconnected the drain hose from the v[COLOR=black]acuum breaker on the sink top connecting to the garbage disposal, aimed the hose into a bucket, cycled the timer and the tub drained into the bucket.
I pulled the chrome cap off the breaker, unscrewed the top and found a wad of gunk blocking the flow.
I removed the gunk, reassembled all and the (18 year old) washer works like new. While I was at it I cleaned the tub float and door mounted spot remover. Wow! I’m ready for a few more years.:slight_smile:
Mike
[/COLOR][quote=denman;158068]Here are your parts
There is a good STICKY at the start of this forum about it’s use.[/quote]
