Magetron fan and light on when door is shut
Hi guys:
I have a GE microwave (JVM1851BH06) with a magnetron blower and interior light that comes on when the door is shut. No cooking cycle is selected and pressing STOP does not stop the magnetron blower from running.
I suspect it may be due to a bad relay…if so, can anyone recommend a place to buy the relay online? Sears.com has the entire board for $163. :frowning:
Any help appreciated.
** Also just discovered relay RY01 is closed, other relays are open. Board was diconnected from power when tested.
RY01 was stuck closed, replaced it and all is working.
Good job!
Where can you get this relay? I can’t seem to find the part number on this site.
Thanks,
Greg
