machine stopped, started then stopped
Last week I went to start a load of laundry and nothing happend, so I started investigating. After checking for siple issues (circuit, outlet, plug…) nothing happend. I kept messing with the controls and all the sudden it filled up, so I thought I was in the clear. Well it filled up then nothing! More research lead me to think the lid switch was bad, so I replaced it. still nothing… So…
A. Is there a fuse or reset switch associated with the lid switch?
B. After replacing the lid switch do I need to drain the washer and start over?
C. What othe troubleshooting could I do if none of this works?
Thanks in advance!
I would suspect a bad timer AP3037984. To confirm, remove it’s cover and check for burnt contacts.
