M-T WASHER STOPS DURING END OF SPIN CYCLE AND FLASHES SUdS......
This is a Maytag small stackable washer. The unit cycles fine until approximately 5 minutes remaining in the final spin. Then it stops, flashes SUdS (or possibly 5Ud5) and the drain pump continues to run until I shut the machine off. I looked inside for a tech sheet, but unable to find one. It appears to run through the high-spin and drain the water, but stops and does the above. I looked at the control board and visibly saw nothing wrong. Any help greatly appreciated. Thank you.
Mike
Mike,
Run the washer empty for a whole cycle, maybe twice, to clean it from the remaining detergent. Use only HE detergent and no more than one tbl spoon.
Thank you Gene, I will give it a try.
Mike
