Lube or not to lube tub seal surface?
Does anyone know for certain if the spring loaded tub seal’s sealing face surface, which pushes up to contact the bottom face seal surface of the basket drive hub, is to be installed dry or with any type of lube? The part number for this kit containing these items is 12001598, which can be found here at this site. Thank you for any experience with this.
No lubricant should be used.
Eric
Thanks Eric.
