LRMVS3006S.ASTCNA0 spaceplus ice maker won't drop ice
Brand: LG
**Model Number:**LRMVS3006S.ASTCNA0
Main Symptom: Splaceplus ice maker not dropping ice
What happens & when: the harvest cycle works when the reset button is pressed
If you place a thermometer between two bags of veggies in the ice maker section, what temperature is measured after 24 hours?
20degF since yesterday
If the freezer craft ice maker is working properly, the power supply cord of the refrigerator would need to be unplugged. Once unplugged, there will be an access panel on the back of the appliance, just above the compressor compartment cover, that would need to be removed. Once removed, a multimeter can be used to test for resistance using the wires at connection CON6 once the harness connector is disconnected from the control. From the light blue wire at pin 6 to the red wire at pin 9 the resistance should measure around 11K Ohms. Do you find this resistance or a different resistance?
