Lower Spray Arm
We have a used dishwasher, and it has started doing this: when the arm spins around, it rakes across the heating element, & makes a knocking sound, is there a way I can fix it or will I have to buy another spray arm? and how do I attach it to it’s base?
Hello,
Make sure the lower spray arm support (#62 at the diagram) and the spray arm installed properly.
Check both, the spray arm and the support.
Here are the breakdown diagrams and Parts for Frigidaire FDB1050REB0 Dishwasher - AppliancePartsPros.com
I removed the spray arm & examined it & couldn’t see anything wrong with it, so I put it back on & ran a empty cycle & the tip ends would tap against the heating element…have you ever heard of this happening before? If there is something I can adjust, I can probably fix it myself…please give me your opinion. Thanks for the feedback.
There are no any adjustments. Try to replace the spray arm.
