Nut holding sprayer arm broke and was replaced. Sprayer arm seems to wobble a fair amount. Is this normal? Neither of the plastic bearing rings seem worn.
Hilreal,
Some “wobble” in a spray arm is normal(1/4 to 3/8 in.),
As long as the spray arm moves freeling, and the bearings aren’t worn, you’re OK.
