Lower Oven Won't Heat
I have a Maytag Gemini electric stove with two ovens. The lower oven won’t heat past 200 degrees. I ordered and installed a new heating element - that was not the problem.:confused: PLEASE HELP!
took the sensor probe out and checked the Ohms it’s working fine.
Parts for Maytag MER6751AAW Range - AppliancePartsPros.com
See that attachment for the tech sheet.
If the oven indicates that it is ready (finished pre-heat) then it is probably the control board.
If the unit stays in pre-heat and both the bake and broil elements are OK then it is probably the control board.
MER6751.pdf (716.7 KB)
