Brand: Whirlpool
Model Number: GBD307PDB09
Main Symptom: Lower Oven Door Locked
We are the original owners of this 23 year old oven. The lower oven door is locked despite that I have never used the self-cleaning feature on this unit and don’t recall if I have ever even used the lower oven. I always use the upper oven.
This is the 2nd or 3rd time the lower oven door has locked over the years. The last time, my husband replaced the motor for the lower oven door latch. There is absolutely no reason why the motor could have failed now since I never use the self-cleaning feature.
My husband is a retired electro-mechanical technician with several Fluke meters. In the past, he repaired the control board to component level once and has replaced it once on this unit, but we can’t recall what the issues were at that time.
Please provide a copy of the service manual and troubleshooting steps to help determine what is causing the lower oven door to lock. Please also include what you suspect to be the most likely issue.
Thank you!
