Lower element no heat
Jenn Air Double oven won’t heat bottom element on upper oven. Element tests ok. I swapped element and temp probe to bottom oven and works fine. Broil & convect ok as well on both. When setting bake temp I could hear relay click. Display has been dim for a year but still worked fine. Points to relay board?
[QUOTE=Chad_targa;291585]Jenn Air Double oven won’t heat bottom element on upper oven. Element tests ok. I swapped element and temp probe to bottom oven and works fine. Broil & convect ok as well on both. When setting bake temp I could hear relay click. Display has been dim for a year but still worked fine. Points to relay board?[/QUOTE]
I would agree!!! Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Thanks!
Think my display will light up again
[QUOTE=Chad_targa;291594]Thanks!
Think my display will light up again[/QUOTE]
You never know!! Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
