Low flame how to adjust
I have a magic chief stove had since new. was not used for couple years, now when turned on all burners on top have low flame holes around burners look to be clean. I was told that it is sealed burners read where their is adj. screw on post after u remove knob did not c one.
MDL#31213wav
SER#31945517ub???:confused: :confused:
Any ideas!!!
thanks
Try using a Jeweler’s screwdriver right down the center of the post. The screws are small. Turn burner on and set it to Low. Remove the knob. Clockwise decreases the flame; counterclockwise increases it.
tried doesn’t seem to be a screw does it matter that ther is only halve shaft not a complete circle?
