Loud Squeaky Dryer Noise
After loading and starting my Maytag MDE3757AYW, the dryer has a loud squeaky noise. Sometimes it runs a few minutes and other times it last the whole cycle. You can also hear a clicking noises at times.
Any suggestions. How can I get an appliance manual for working on this dryer? Thank you.
Replacement parts for MAYTAG MDE3757AYW | AppliancePartsPros.com
Here is the service info
http://www.servicematters.com/maytag_library/docs/16026315.pdf
http://www.servicematters.com/maytag_library/docs/16027535.pdf
Try to find out where the squeal is coming from at least its general location.
Sometimes this is impossible.
Could be the rear support rollers, the idler wheel, the front glides or the motor bearings. With a little luck spinning them will indicate the culprit.
Check the bearings for slop and wear.
A drop of a decent oil on the shafts may help if the bearings/shafts are OK. Do not use WD40 as it will not last long. Also do not over do it as the oil will hold lint.
Also may be something has fallen into the blower or it is loose.
