Loud roar from washer on spin cycle
My washer is making a very loud roar when it’s in the spin cycle. Could this be a bearing going bad? If so is it easier to change the bearing or the whole tub assembly? what causes the bearing to go bad, washing too many clothes at one time? Any help would be appreciated!
Hi.
The tub bearings come as apart of the outer tub. You need to replace the tub AP5306816
Overloading and slow water leak may cause the bearings go bad.
Here are the breakdown diagrams and Motor, Basket and Tub parts for Whirlpool WTW6200VW0 - AppliancePartsPros.com
Simon.
H
