[SIZE=5]My wife turned on the oven and a very loud pop was heard. It blew the breaker to the whole house. Now the oven doesn’t work (either element) but the stove top is ok. Convection fan also runs. Elements seem ok. Any suggestions would be appreciated. [/SIZE]
Here are the parts for a CB4, yours should be a close match
Replacement parts for FRIGIDAIRE PGLEF385CB4 Frigidaire Canada/electric Range | AppliancePartsPros.com
Here is a wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318046713.pdf
First I would unplug it and find out what popped.
Look for burned off wires and tell tale weld/arc marks.
Check the timer/control board for blown components.
Since the convection fan runs, I assume that the oven light is also OK. This indicates that your power is OK re: Neutral is good.
Good stove top element heating indicates that the 240 volts is OK.
You did not say if the timer/clock (control board) was not running.
Need more info on the symptoms.
[QUOTE=fozie9;179517][SIZE=5]My wife turned on the oven and a very loud pop was heard. It blew the breaker to the whole house. Now the oven doesn’t work (either element) but the stove top is ok. Convection fan also runs. Elements seem ok. Any suggestions would be appreciated. [/SIZE][/QUOTE]
If the top burners work, then there will be no power issue. It will most likely be the clock control board. It controls the oven. The part # is 318193201 Tom ApplianceEducator.com
I will check out your suggestions. Everything except the oven elements work. The clock, timer etc are operational.
[QUOTE=fozie9;180041]I will check out your suggestions. Everything except the oven elements work. The clock, timer etc are operational.[/QUOTE]
Pull the back panel off the oven, and see if there is a broken wire from one of the elements. Tom ApplianceEducator.com
Checked out the wiring and control panel, no signs of any burned wiring or black marks etc. The wiring for the elements seems very simple so I guess it has to be either an element problem or a component of the control panel.
[QUOTE=fozie9;180072]Checked out the wiring and control panel, no signs of any burned wiring or black marks etc. The wiring for the elements seems very simple so I guess it has to be either an element problem or a component of the control panel.[/QUOTE]
I would get a cheap volt/ohm meter at radio shack for 20 bucks, and ohm out the element. Or if you have a part house near you, they could most likely ohm it out for you. If it is good, you will need to replace the clock control. Tom www.appliuanceeducator.com/parts.htm
This happen to me too.The only diference is the clock is not working.Please help
borgli
If your model number is different I would start your own thread using “Post New Topic” Units can vary greatly in how they are wired and some units have a fuse for the control board.
The basic troubleshooting is the same.
Check for fried wires and blown up components and check the power going to the board. The board has 220 volts going to it for the elements but also should have 120 volts which drives the electronics. Note some units have a relay board which sometimes provides a lower voltage to drive the board.
[quote=denman;180809]borgli
Check for fried wires and blown up components and check the power going to the board. The board has 220 volts going to it for the elements but also should have 120 volts which drives the electronics. Note some units have a relay board which sometimes provides a lower voltage to drive the board.[/quote]
Thank you Denman.
My model # is cfef372cb2 and exept few posts,I can’t find anything else about this model.I posted here since we are having the same problem.
I have checked both elements with a meter and they are fine, so I guess I’m looking at the control panel, although everything on the display works, it even indicates the oven is on, but I guess there are modules on the board that control power to the elements.
Thanks for the continued help.
[QUOTE=fozie9;180919]I have checked both elements with a meter and they are fine, so I guess I’m looking at the control panel, although everything on the display works, it even indicates the oven is on, but I guess there are modules on the board that control power to the elements.
Thanks for the continued help.[/QUOTE]
If the elements are good, you need to replace the clock control. Tom ApplianceEducator.com - Parts
Looking at the parts list, looks like the control board is obsolete.
You will have to phone or email AppliancePartsPros to see if it is available.
If not there are companies that repair circuit boards/timers.
I have never used one so cannot make a recommendation perhaps kayakcrzy can. Also I do not know what they charge.
[QUOTE=denman;181118]Looking at the parts list, looks like the control board is obsolete.
I have never used one so cannot make a recommendation perhaps kayakcrzy can. Also I do not know what they charge.[/QUOTE]
I too found the part no longer exists. You could send the clock to these people here at this link low cost appliance parts for the do-it-yourselfer They can rebuild it for you. Tom www.applianceeducastor.com
O.K.Now I realize why is so hard to find answer to these questions about the clock.New part costs CAD $339.00 and they dont have it in their inventory,so 3-4 days for delivery.New range is 749.00 so I’m picking one up.I’m sure everyone else does the same thing.Feel bad to throw it in the garbage since everything else on it works good and it looks like new.
[QUOTE=borgli;181660]O.K.Now I realize why is so hard to find answer to these questions about the clock.New part costs CAD $339.00 and they dont have it in their inventory,so 3-4 days for delivery.New range is 749.00 so I’m picking one up.I’m sure everyone else does the same thing.Feel bad to throw it in the garbage since everything else on it works good and it looks like new.:p[/QUOTE]
That is how it goes. For that cost, O would buy a new stove too. Tom ApplianceEducator.com
I had the exact thing just happen except I wasn’t even using the stove or oven. It just popped and all the electricity went out. Now the oven doesn’t work. The light and convection fan run. The time works. Some of the numbers to set timer or temp don’t work either. Why would it do that if not even being used?
