Loud noise when spinning
Brand: LG
Model Number: WM0642HW
Main Symptom: Load roar when spinning
What happens & when: Sounds like a jet taking off when it spins
Error Code (if any): none
Parts or tests already tried: diagnosed to suspected hub bearing. How do I determine if I need a tub ball bearing or a drum ball bearing?
For model WM0642HW, if you’re going to go through the time, effort, and hassle of tearing the machine down to replace one tub bearing, it’s highly recommended to replace both bearings and the tub seal at the same time.
The majority of the labor involved is getting the washer completely disassembled to access the bearings. Once you’re already in there, the additional cost of replacing the second bearing and seal is relatively small compared to the work required to get back to that point later.
The last thing you want is to reassemble the washer, get it back in service, and then discover a short time later that the other bearing is starting to fail. Likewise, if the seal is worn or damaged, it can allow water to reach the new bearings and significantly shorten their lifespan.
Replacing both bearings and the seal while the washer is apart helps ensure a long-lasting repair and reduces the chances of having to tear the machine down a second time. It’s a classic case of “doing it once and doing it right.”
seal (https://www.appliancepartspros.com/lg-seal-4036er2004a-ap4438637.html)
Drum Bearing (https://www.appliancepartspros.com/lg-bearing-ball-4280en4001f-ap5972810.html)
Tub Bearing (https://www.appliancepartspros.com/lg-bearing-ball-4280en4001c-ap5672864.html)
Thank you! There is a lot of wisdom in that reply. I will order and replace all three parts :slight_smile:
