Loud noise when spinning
I own a Whirlpool WTW5057LW0 top load washer that is loud when spinning. Still works okay although when spinning it’s so loud.
As it spins up it gets louder and louder.
Hi Reed, thanks for your post.
From what you’re describing, it sounds like the washer is probably roaring like a jet engine during the spin cycle. That’s a classic sign of failing tub bearings, which are built into the gearcase on this model.
To correct the issue, the gearcase assembly would need to be replaced. Here’s a link to the item information page for your washer:
:backhand_index_pointing_right: Whirlpool Gearcase – W11449840 (AP7192627)
Let us know if you’d like any help with the replacement steps—we’re happy to assist!
