Loud Banging noise on way down and up
Kitchen aid trash compactor model KUCC151LSS0 5 years old.
on its way down it is making a loud banging noise , the ram goes up and down but just more loudly all of a sudden.
I am assuming greasing the ram screw would fix the problem but not sure plus I have no schematic diagrams. and i don’t want to start tearing it apart with out a little insight from the pros.
any advice and some diagrams would be helpful
thanks in advance
[QUOTE=chrisawol;596100]Kitchen aid trash compactor model KUCC151LSS0 5 years old.
thanks in advance[/QUOTE]
Ok I found the diagrams on this site with all the parts list.
Now I need to know what to look for that is making the banging noise so i can fix or buy replacement parts or grease screw
Any advice
Bump Help :smiley:
[quote=chrisawol;596100]Kitchen aid trash compactor model KUCC151LSS0 5 years old.
thanks in advance[/quote]
Try looking at the split nuts on top of the auger screws. Initially, you may have to remove the hold down bracket over the nut, split the nut and raise 1 side so it is level. If the problem continues, you may have to replace the worn split nut sets so the ram travels up and down level.
sorry never replied I found it I took it all apart and the large nuts on the bottom of the thread rod that run the compactor up and down were loose. tightened them back up tested and everything is good been about a year so far
