Lost
dishwasher was working fine till the other day then all the lights went out. I checked for voltage at the control panel have 110 volts. power in and out of the door switch,thermal fuse is good, replaced the control panel and no change where do I look next? thank you
Here are your parts.
I think it is a GU2455xtsQ0 not a GU2455xts00
Parts for Whirlpool GU2455XTSQ0 Dishwasher - AppliancePartsPros.com
Sounds more like a control board problem than a control panel (keypad) problem to me.
It is often a gamble as to which of these is causing the problem.
GU2455XT.pdf (244.0 KB)
Sorry the control board is what I already replaced is there any way to check the keypad before replacing it?
[COLOR=“Blue”]is there any way to check the keypad before replacing it?[/COLOR]
Yes but you need a meter.
Take a look at the tech sheet I attached earlier.
checked out the tech sheet but I don’t see what to test to check for the key pad. I checked the fuze, the door switchs and since I already replaced the control board I don’t see what else it could be?
Sorry for not responding earlier but I was out at the lake.
The keypad check procedure is on Page 2center bottom of the tech sheet.
Note that it only checks the keys.
Thank you test proved it is a bad keypad, again thank you this should make the wife happy:)
