Brand:whirlpool front loader washer
Model Number:
Main Symptom:
Model Number:
Main Symptom:
I will need a model number, it probably has a coin catcher that may have captured it.
Model Number:
Main Symptom:
I lost a necklace in the washer. I was wondering if you can tell me how to maybe find it. I checked the
I may be able to help if you give me a model number so I can see what type of front load washer you have.
David,
The model number is : WFW4720RW0
This model does not have an access panel at the bottom to get into the pump. You would need to remove the top, the console, and the entire front panel to get to the pump clean out. If it has made it through the tub drain to the pump, this is where it would have landed. It is just a time-consuming process to get to the pump on this model.
David,
My son found it in pump clean out on front of the washer. I did another load of laundry and the water moved it to the clean out.
Cathy
