Looking for advice on how to replace hidden bake element in my oven
Brand: Maytag
Model Number:MER6600FZ3
Main Symptom: oven heats slowly, likely bake element but I am unable to access hidden element
What happens & when: preheat takes double the time it should or fails to heat entirely.
For this one you would be taking off the left-side (when facing the front of the range) body panel and bending down the side of the burner box to access the element and the screw holding it.
Before you start trying that though, sometimes slow preheat isn’t because of the bake element. Does it seem like the broil element is coming on during preheat, can you see it glowing? These use the broil and bake elements to reach temperature during preheat. The bake element is a fair bit weaker than the broil, so slow preheat may be an indicator that your broil element isn’t coming on.
