I have a Samsung Dishwasher DW80R9950US-AA. I’m looking for the gasket that would go around the water vane/ water wall motor housing that you reattach to the bottom of the tube and spary arm. I can’t find it anywhere. In your diagram, it’s located on the Inner parts assembly as 1-1-2-5 (I believe it’s a 5).
That page is deceptive, 1-1-2-5 is almost at the bottom. Part # is AP4341733.
https://www.appliancepartspros.com/samsung-seal-distributer-dm14-dd62-00054a-ap4341733.html
This does not look like the same part I need. And when I look at the cross reference information on the part, my model is not listed. The gasket I need has a much thinner width (1/8” in thickness), Is 4 1/4” diameter, and 5/16” tall.
Would you please find out what the correct part is? I would really like to replace it.
Hmm, I can see it on the diagram and your description matches how it is represented there, but DD62-00054A (our part # AP4341733) is what pulls up even on the manufacturer’s parts list for this model, and that is much smaller than what you’ve got.
Could you attach a picture of the gasket and where it is supposed to go in the dishwasher? Just wanna make sure I’m looking in the right place.
It would go around the part that holds the waterwall motor and then attaches up thru the base to the water vane fixture (or whatever it’s called).
They’re not listing a gasket like that anymore, which means that it will now only come with an assembly. Looks like they’ve discontinued 1-1 and 1-1-2 which might have had it with them. From there it seems like you’d have to order the motion assembly AP6885083 to get that seal.
https://www.appliancepartspros.com/samsung-assy-motion-dw9900r-dd97-00484d-ap6885083.html
Well that sucks. I’ve already replaced too much on this dishwasher to make it worth buying that too.
I’ve looked up that part elsewhere and it doesn’t show that gasket coming with it
