Locked but unresponsive Maytag
Recently our dishwasher hasn’t been easy to start. I’ve been able to start it by pretending it was locked and holding the button for a few seconds and then it would start - the lock light wasn’t lit. Now the locked botton is lit, but holding the button doesn’t unlock it. I didn’t know if I needed to replace the circuit board, or the push button control or it there was a simple fix. Thanks, Dave
Model MDB7601AWS
Here is the tech sheet and a service manual with operators manual
http://www.servicematters.com/maytag_library/docs/16026393.pdf
http://www.servicematters.com/maytag_library/docs/16021814.pdf
First try to get rid of the lock. See page B-9 in Operators Manual
Next thing I would try is disconnecting power from the unit for half an hour or so. Sometimes the electronics can lock up, the above may reset them
Next try the diagnostics
Next try cleaning the ribbon cable re:Control Panel
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
