Brand:GE
Model Number:gdf670syv1fs
Main Symptom:locked control panel
What happens & when: I installed a new control board from y’all
Brand:GE
On the GE GDF670SYV1FS, if the control panel became locked after installing the new main control board, I would first treat this as a Control Lock setting, not assume the new board is defective.
With the dishwasher powered on and the door open, look at the buttons for a LOCK / Control Lock symbol. Press and hold the button associated with that lock symbol for about 3 seconds.
You should hear a tone and the lock indicator should go out. Then close the door and try starting a cycle.
If the panel still shows locked and ignores the unlock command, I would go back to the recent board installation. Disconnect power, then reseat every connector at the new main control board, particularly the communication/UI harness. Look closely for a connector that’s not fully seated, a backed-out terminal, or a pin that got bent during installation.
