Lock button stays on
:confused: Our dish washer red lock button stays on and will not let the washer start… I have pulled the front panel to make sure the connectors are solid, sprayed contact cleaner all over, made sure the handle was functioning. When you pull the handle the light goes off but will not let the washer start. Any suggestions on how to reboot this old girl??? or any other fixes I can try???
LOCKON
When LOCK ON is lit, all buttons are disabled.
NOTES:
• The dishwasher door can be opened while the controls are locked.
• You can turn on the Lock while the dishwasher is running.
To turn on the Lock
Press and hold the NO HEAT DRY button for 4 seconds.
LOCK ON glows.
If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds.
The light turns off.
Thanks for the quick response.. I did all that plus shut power off for at least 10 minutes with no luck. I pulled the dishwasher and put it outside to air out… Thanks again we got over 20 years of service out of this one and I would say that is pretty good these days…
