Lint filter and housing
I have to replace my lint filter and filter housing. I received my parts with no instructions! The manual is no help. where can i get instructions or schematics? I am a disabled widow and would appreciate some help.
Well, the easiest way is for you to have a service manual. So here it is. Once you take off the front cover it will be obvious how to replace the parts. The schematic is obtained by clicking on your model number.
http://www.servicematters.com/maytag_library/docs/16026315.pdf
This is an easy, but not necessarily intuitive repair, so you should be fine once you have the directions, which you now have!
