Front light’s on for normal wash but nothing is happening. Turned power off for few minutes, back on same problem. Water, electricity, all good. No other run options light up. If I hit “light wash” the normal wash button lights up. HELP!
Most likely the problem is a bad control panel but there is a small chance for the control board to be bad as well.
I would replace the control panel first. If you need the correct part number, post the color of the control panel.
Here are the breakdown diagrams and Replacement parts for Maytag MDBH968AWB3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
That’s where I’ll start, afraid that was what it might be.
