Lights come on/ no go
Hi guys …having dishwaher probs…when you hit the wash button the light comes on…stays on for a bit (30s-min) than shuts off…dishwaher does nothing…hoping it’s not a control board prob…maybe just has to be reset(I hope)…Cheers :frowning:
You may want to start the troubleshooting with checking the door switches (part of the door latch - #12 on the diagram). Make sure they are properly engaged when the door is latched.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE GLD2250RDC4 Frigidaire/dishwasher | AppliancePartsPros.com
[QUOTE=Gene;237401]You may want to start the troubleshooting with checking the door switches (part of the door latch - #12 on the diagram). Make sure they are properly engaged when the door is latched.
Gene.[/QUOTE]
I thought if the door switch was bad, I would’nt get any power to the board or panel etc.. I’m prob out to lunch with that idea …I’ll try to check that out…Thanks for the reply.
You are welcome.
If there is nothing wrong with the door switches, perform the Service test as instructed in the Tech sheet (page 2).
