I am having difficulty installing the light shield. There are two studs that the shield hangs from but the lower part of the shield does not seem to match up with the slide tray to secure it. I had the same problem with the original part and the bulbs melted it. Do I have the gasket installed correctly? Is there a diagram on how it is to be properly installed?
This is a light shield and not part of the ice maker.
