Good Morning, We have a Samsung refrigerator that gives a very light shock from the door handles or case. The refrigerator is less than a year old. Any idea what could be going on? Thanks:confused:
Are you sure it was not a static electricity shock?
What kind of floor is in the kitchen?
Also
Is it plugged into a properly grounded 3 prong 120 volt outlet?
Or is this an older house with only 2 wire wiring (no ground)?
Does it happen all the time?
Is it like a static electricity spark (shock) or is it an electrical tickle?
This is on an all tile kitchen floor. And the feeling is more like an electrical tickle.
Does it only happen when the compressor and the fans are off?
Similar problem with a Kitchenaide side-by-side refrigerator with icemaker on the left side door. There can be, infrequently, a 115VAC shock if you touch the left side metal door front. I measure from 13VAC to 115VAC, randomly, with a DVM touching the black ground wire of the meter to the Ground pin in a nearby socket and touching the red meter wire to the metal front left door.
By removing the bottom front black plastic panel, I see the 2 wire connectors that go to the Icemaker system. Disconnecting both of these connectors eliminates the AC voltage and eliminates the shock. Now I know that the shock is being caused by the ice maker wiring. I have not yet pulled that apart to fix it… but at least it shows that the icemaker wiring can short out to the metal front door…
- Michael
