Lid Lock Blinking in Rinse Step
Brand: Maytag
Model Number: MVWC200BW1
Main Symptom: Lid Lock Blinks
What happens & when: Rinse step
Parts or tests already tried: new lid lock and shift actuator
I have a Maytag Centennial, see model above. Initial symptoms were lid-lock blinking and not leaving fill cycle. Installed new lid lock switch and shift actuator, now washer makes it to rinse step, then the lid blinks. It also hums real bad and nothing moves. Water strainers are clean and suspension seems to be in good shape.
As a customer facing error the Lid Lock light blinking indicates an error with the drive/motor system. Have you run it through the diagnostic test to see codes or check component activation? If not, here’s the tech sheet to give you a hand with that.
TechSheet-W10677676-RevB.pdf (2.9 MB)
