LG WT7300CW Washer leak
Brand:LG
Model Number:WT7300CW
Main Symptom:leak
What happens & when:drain Error Code to pump hose. (if any):
Parts or tests already tried: I removed the black hose that connects tub to pump. There was a lot of water on tub side of pump that came out of hose. Could this be the pump
That sounds like the drain pump AHA75673401 is bad, especially if it runs but doesn’t seem to be moving much water.
https://www.appliancepartspros.com/lg-pump-assembly-drain-aha75673401-ap6335290.html
