LG WT5270CW washing machine IE error after valve replacement
Brand: LG
Model Number: WT5720CW
Main Symptom: IE error
What happens & when: Intermittent IE error (~20% of cycles), valve may be shutting off too early. Previously would get FE error on machine occasionally and inlet valve wouldn’t close (would stay open, filling for >1 hr and draining constantly). Technician confirmed inlet solenoid bad. I replaced inlet valve (Part # AJU75152601). Machine now works normally 80% of the time, but will display IE error occasionally. When IE error is displayed, tub is ~half full and appears the valve closed off too early. Turning machine off & restarting, the cycle runs fully without issue. Checked inlet valve filters (no debris), inlet valve hoses (no kinks, fills normally most of the time), and electrical connections on inlet valve (all secured).
Error Code (if any): IE
Parts or tests already tried: replaced Part # AJU75152601 after getting FE error, no longer get FE error but do get IE error now
Sounds like a possible pressure issue as the washer is not filling as quickly as expected. Check the connections and screens again, if they are all good you will need to check the water pressure to the machine to ensure it is high enough.
Hi- can you explain more about this being a pressure issue (versus a faulty new valve?). The machine will run fine for say, 3 cycles in a row, and I can watch the water running in at a normal rate. Then on the 4th cycle it doesn’t fill enough and throws an IE error, but upon restarting a few minutes later runs fine. I would think a pressure issue would not be so intermittent (and I’ll note there are no other major water consumers in the house running when the IE error has come up).
