Lg wt1101cw washer not draining
Brand: LG
Model Number: Wt1101CW
Main Symptom:
We just had a new water pump installed into the washing machine and it is not activating. it’ll start to fill with water, but it will not drain it if I take the hose out and use gravity though water will drain and it will go onto the next cycle. If I lift the hose back up, it will fill up again and go to the next cycle. Is it possible it is the pressure switch that is not activating the pump or what could it be that’s not activating the pump. The washing machine had been working brilliantly the past year and a half. This is for our company and we need to have this running as soon as possible.
Error Code (if any): IE code but that code goes away when I lay the drainage tube to drain into the floor
On the LG WT1101CW, I would not replace the pressure switch yet. Your gravity-drain test is useful: since the water flows freely when you lower the hose, the tub-to-pump/drain path is probably open. The bigger question is whether the new drain pump is actually receiving power when the washer commands a drain.
The service information gives a very good test for this model. In service mode, the drain-pump test is reached on the 9th press of Start/Pause. With the pump commanded ON, you should measure approximately 120 VAC at the drain-pump connector. The manual specifies 120 V ±5% with the pump running and roughly 0–1 V when it is off. manualzz.com
I would check it this way:
  1. Enter service mode and advance to the pump test.
  2. Listen/feel for the new pump. If it remains completely silent, check voltage at its connector.
  3. 120 VAC present but pump doesn’t run: the new pump is defective, incorrect, or has a poor connection. The service manual specifies the pump winding at approximately 10–20 Ω. manualzz.com
  4. No 120 VAC at the pump: inspect the pump connector and wiring back to the main control. If the wiring is good, the main control board becomes the leading suspect. The WT1101CW service troubleshooting chart specifically directs you toward the main PCB when proper pump output voltage isn’t present. manualzz.com
The IE code is actually a fill/water-supply error, not the normal drain error; a drain failure is normally OE. Appliance Factory Parts In your situation, the IE may be secondary to the unusual water-level situation created by manually lowering and raising the drain hose.
The pressure switch can certainly cause water-level problems, but I wouldn’t start there. The service manual only sends you toward the air chamber, pressure hose and pressure switch after checking the pump circuit, based on the water-level frequency reading. manualzz.com
So the quickest test is: command the drain pump ON and meter its connector. If you tell me whether you get about 120 VAC or 0 VAC, I can tell you which direction to go next without guessing or buying another part.
Sounds good I have to get a meter
I appreciate the help. However, work decided to just throw it out and buy a new one.:face_with_raised_eyebrow:
