I have a LG WM0642HW front load washer that behaves as follows:
[LIST]
- Runs a normal wash cycle, everything appears to works fine
- Alarm that cycle is done goes, control panel turns off and unlocks the front door. Again everything appears normal.
- Then cold water start filling the drum and will not stop.[/LIST]I turned off the cold water supply and then powered the washer back on and had it run a rinse/spin cycle. It seemed to run fine and pumped the water out. The washer does not behave this way at every use. It has done this twice in the last 4-5 loads though. Is this likely the cold water inlet assembly problem or perhaps the circuitry that controls the valve?
— Thanks for the help, Jerry
