LG Wm4070hva Washer - vibration at high speed
Brand: lg
Model Number: Wm4070hva
Main Symptom: vibration at high speed
What happens & when: spin cycle at speed the tub vibrates. When it’s stopped, the front of the tub can be lifted almost an inch. Should I order just the Gasket ? It feels like the baring Tub Ball Bearing is solid when I spin it by hand.
Is it just the inner tub that seems to be vibrating or does the whole machine start vibrating/shaking/walking?
Just the tub and only when it gets over 3/4 of top speed.
Does it do the same thing if you run a cycle with the tub empty? Try putting it on the drain/spin cycle and letting it run with nothing in there to see what happens.
If it is doing this same thing with the tub empty you might have a slight warp to the inner tub.
