Brand: LG
Model Number: wke100hva /02
Main Symptom: 1E code
Error Code (if any): code comes on about 3/4s of the way through normal cycle. Then machine just beeps and stops.
Parts or tests already tried: cleaned water line filters. Checked water pressure. Checked drain pump filter. Checked drain tube into discharge 2” pvc. All seem good to me. Washer will preform a full quick wash. I can hear and see water filling machine upon start up and observe discharge water. I think I may need a new water level sensor or pressure switch? How do I go about doing that? From the front of the machine? Any links to the part? TIA
