LG Washer
I have a LG model WM0642HW and has been giving me the OE code, we have cleaned out all the drain hoses and replaced the pump and the machine still gives the OE code. We than replaced the control board but are getting the same error code. The problem occurs at 37 minutes rinse and spin cycle. Sometimes if you thump the machine it will start running again? What would be causing this problem? Thanks
I am having the same issue but on model WT1101C. I’ve checked the drain and drain tube for blockage, I’ve even tried a different drain location. I’ve removed the pump and tested it. The pump works. I cannot find a diagram so I am not sure if the control board is next or something else.
Where did you find the parts for your washer? I was very surprised I couldn’t find anything on APP for my unit. In fact I don’t see much on LG washers.
Thanks,
Miller
I replaced the control board and the pump both and still have this problem. I purchased the parts from www.************************.com. They offer a 365day refund on the parts if the new part does not fix your problem. For the moment I have the washer pulled out about 8 inches from wall when it stops running, I lean the washer back, lifting the front about 4 inches and drop it to the floor. This always gets it working to finish the load. I will take it apart again for the fourth time and just check to make sure there is nothing is between the two tubs.
