LG washer leaking from front drawer
Brand:LG
Model Number:WM3001HRA1
Main Symptom: LEAKING
**What happens & when:**Part Scout
AI Assistant
11:18
Email : [[email removed]](mailto:[email removed])
To get started, what do you need help with? : WM3001HRA1 LG washer. Have a water leak from the detergent tray door. There is no clogs or blockage, but if I pull drawer all the way out. Start the washer. The front tray water dispensers are spray straight towards front of unit. So when drawer is installed. Water runs down front of washer. Enough to make small puddle every wash. Would replacing the dispenser assembly be my part? Thank you in advance.
Parts or tests already tried:There is no blockage or clogs. Water just sprays forward in tray. Causing it to leak down front.
Somewhere there is an obstruction causing the path of the water to be re-directed toward the front of the tray. Pull the hoses off the back of the dispenser housing and look inside each port to see if there is something partially blocking the water path. Clear them out idf you can with a small brush.
I’ve already took the unit completely out of washer. Unsnapped the top from bottom. Sprayed bleach and scrubbed entire piece. Holes are all fully open. It is like either the holes have gotten bigger or something. With the drawer completely out. The right side fill has about 3 to 5 spray holes that spray completely out of washer. Totally mis direct spray. I also put pressure reducers on the water lines thinking my pressure was too high. That did not help either.
I’m leaning towards replacing that whole assembly. Maybe hot water or high pressure over time has deformed that box with all the little fill holes in it. It seems replacement is my only choice to try.
This is what it does as it fills. The water fill is completely clean and clear
