LG washer IE error code
My LG washer is showing an IE error code. The cycle will start as normal but when it gets down to either 32 or 34 minutes, the timer stops advancing and so the unit shuts down and displays this code. I am not sure if it is the PCB assembly or the main circuit board that needs to be replaced.
Multiple attempts top reset the unit with the plug pulled and the on button depressed have not cleared the issue/fault.
Any suggestions or experience with this would be greatly appreciated.
Thank you.
Hello. The IE failure code is an inlet valve problem,
AP4442608and AP4441935
[model]WM1814CW[/model] Thank you and good luck !
