LG Washer Error Code tE
I have an LG machine, model WM0642HW. I’ve received an error code of tE which I had been directed by an LG rep meant that I had a bad thermistor. My question is, if I purchase a thermistor is it required that the panel assembly control be replaced as well?
Did the LG rep you talked to say that the panel assembly control should be replaced as well?
