LG Washer Code UE
Brand: LG
Model Number: WM8000HVA
Main Symptom: Code UE
What happens & when: It stops.
Error Code (if any):UE
Parts or tests already tried: K121 Washer Tub Ball Bearing , K122 Washer Tub Bearing, K123 Washer Motor Rotor Bolt, K125 Washer Rear Tub Gasket, K141 Washer Door Gasket, K360 Washer Rotor Postion Sensor Assembly, K610 Washer Shock Absorber Kit (3x)
Hi john3133,
After replacing those parts and still experiencing this error code, have you performed a reset or calibration procedure on the main control board?
With the power off, press and hold Spin Speed and Soil Level (on some models, Temp and Spin Speed) at the same time, then press Power. This should place the washer into the service or calibration mode. Running the calibration cycle can help the control board relearn the machine’s operating parameters and may clear the error if the new parts are functioning properly.
No I have not perofrmed a rest or calibration. I will try that next. Do you you think the Main Control Board could be the next thing if this doesn’t fix it? Not much left to replace. I replaced the bearings because they was making a loud sound, but the drum still felt tight. The loud noise is gone now.
Before I rule out the control board, I would also check the weights around the tub and make sure they aren’t cracked or loose. A damaged or loose counterweight can cause excessive vibration
Take a look at those components
Yes I have checked those adn they are in perfect condiation and they are not loose. I will see how it does after a calibration.
