LG Top Load washing machine Model : WT7200CW
Brand: LG
Model Number: WT7200CW
Main Symptom: IE CODE
What happens & when: AFTER SPIN THEN FILLS UP THEN THE IE CODE shows up and machine stops HOSES ALL GOOD, cleaned the intake valve filters hot water one has a little orange to it but clean otherwise. I’ve unplugged it and also checked all hoses, water pressure is very strong going into the valve but it but seems water into actual unit is a little more than a trickle. and then the code IE I started opening it and then move the laundry around it starts up again then maybe 15 mins later the IE Code and then same thing and finally get the washer to finish. But I’m assuming it isn’t getting enough water into the actual washer so how to fix? what part should I try first? thanks in advance!
Error Code (if any): IE
Parts or tests already tried: Cleaned intake valve filters and unplugged and checked all hoses
Based on the symptoms, this issue will likely be with the water valve which here is a link for the part.
https://www.appliancepartspros.com/lg-valve-assembly-inlet-aju75152601-ap6308239.html
