LG Fridge LMXC23746D makes ice, dispenser door opens, courtesy light comes on… but no auger so no ice comes out. Also, water dispenser does not dispense (2 separate paddles) though same light comes on when water paddle is pressed. Other than the clicks made by the switches, no other sounds.
Based on the symptoms list in the dispenser parts diagram at APP, I replaced the sub PCB board AP5604908 / EBR60388503. No change in behavior. All wiring on the control panel looks good, intact, no corrosion nor buildup I could see. Connections solid.
Any other ideas?
Teamfindley, thank you for your question. As there is no wire issue, and the dispenser power control has been replaced, the failure would be in the display board EBR72955425/AP6028878 not communicating to the dispenser power control. This would be based on the dispenser switches having continuity when pressed.
OK so I replaced the display board… no change in behavior. Courtesy light comes on when asking for water (no other sounds) and the ice door opens when asking for ice (no other sounds.)
The icemaker is keeping up on making ice. I pull ice out manually every day and it continues to make ice.
Where is the solenoid that opens the tap for the water dispenser? I found the ice auger motor, which I supposed I can test, but it seems unlikely that the water solenoid and the ice auger failed simultaneously.
Thanks for any additional ideas you have.
… adding… I found the solenoids behind the water filter panel, and can see a pair sharing a single mount, blue hose for the drinking water, orange hose for the icemaker. Are these 110v?
I should add that all connectors and boards and wires are clean, no signs of water damage, no chaffing. All connections are tight and true. I disconnected and reconnected every connector I could find behind the control panel, icemaker, and water filter panels.
The only thing that caught my eye is the ice auger motor housing has evidence of ice around it. There is what I would call a water line about halfway up. Not as far up as the axle that turns the auger itself. The fridge has frozen up in twice the past 3 years and we just defrosted it manually (empty it and leave it off for a couple of days, wet-vac out the water from the drip tray underneath.) We had just defrosted it maybe a week or so before the issue of no water/ice dispensing showed up.
Yes, it can make ice but won’t dispens ice or water.
Water pressure is good, replaced the filter. Had couple “pro" check it & they said it could be the the switch or wire but they aren’t sure. When i saw this thread of replacing everything & still didn’t work made me back up a little.
I wonder what it could be, i know it’s not water line issue since it’s making ice.
If you unplug the power cord and access the top of the left door, there is a sub pcb that can be rotated once dismounted from the door. With it placed securely (wires still attached and no bare wires touching metal), plug the power cord back in. Using a multimeter, test from the purple wire at the connection CON2 to the blue wire (do not disconnect anything) going to the cabin (wire connector at the door hinge) for 120 Volts AC. Is there voltage when the water dispenser is pressed?
I have the same issue, but I know it is the wiring at the hinge point.
I had to fix the wire on the right door for the deli tray light as it broke from opening and closing the door. One wire broke right at the hinge point.
When I push down on the wires going into the left door it starts working again. I have not been able to figure out how to disassemble the door to get the wire harness out though. It appears that one of the wires on the left door is bad at the hinge point as well. Not sure which one yet.
Unfortunately, the wires inside of doors non-accessible anymore as the doors are insulated with the wires installed. Usually, either the door needs to be replaced or the wire spliced if there is enough room.
I had the same issues. The wire on the right door broke last year that lights the deli tray. I was able to solder it.
Now the left door is no longer making ice or dispensing water. It turned out that the blue wire broke just below the hinge. I had to run a replacement wire under the seal and drilled a hole up to the wires behind the water filter. It works again.
