I am still fighting with my refrigerator. Initial problem:
-Water will not dispense when selected
-Ice will not dispense when selected
Led changes position when pressed
Refrigerator is cooling and freezing normally
- Seems like door interlock issue so test the door mag switches with a strong magnet. Open door light is on, put magnet on door sensor it is off (so not that simple issue)
- Check ice maker, Unload it, An hour later full of ice (so not a water issue)
- I take apart the entire front panel (Not easy as there is no video for this model) Check the dispenser switch. it measures continuity when pressed repeatedly (so not the switch)
- No special event but now front panel lights are not on
- Measure voltage at the back of control panel 12V and 5V are OK
Question: Refrigerator is cooling and freezing so the controller seems to be working except for light and controls. How is this possible if control card is wrecked?
Question: Is there a lock on the front panel? How to disable?
Question: any suggestions?
Question Do I order LG ACQ88651527 Cover Assembly,display (AP6306257) - AppliancePartsPros.com
